Peters Web Site
Date:  8-5-2023
Number of Hours:  3.00
Brief Description:  AUX Fuel Pump.
Over night I have been thinking about why the AUX fuel pump was not working.
Today I checked all the wiring to the AUX fuel pump.
Positive and negative were correct, earth wiring was OK, I had power to the pump ( 12.5 Volts ), the AUX pump switch worked OK, nothing was reversed.
The multimeter got a very good workout to no avail, every thing seemed to be as it should.
I decided to do an airline engineering procedure which I have seen many times over the years, it is referred to as a " TT " ( Technical Tap ).
I applied power to the pump from an external battery and lightly tapped the pump with a small hammer.
To my relief and surprise the pump leapt into action and has not faulted since.
The pump had sat idle for a number of years and just needed some encouragement to work.
Total hours .3 of an hour, therefore, 18 minutes running yeaterday.
AUX pump on.
AUX pump on.
Fuel pressure 3.6 PSI
The Technical Tapper.
