A significant day today with the first start of the engine. With the help from KSC and BDH we moved the aircraft out to the side yard. We chocked the wheels, set the park brake and then I tied it to a tree, just in case it wanted to do it's own thing. The engine started immediately without any hesitation. Oil flowed from the turbo oil line within seconds and after I shut it down we reconnected the oil hose to the oil tank. The second start was immediate as the first start was, all temperature and pressure gauges indicated correctly. The alternators worked perfectly. The only problem I have is the AUX fuel pump is not working. We have no leaks from what we could see, other than the AUX pump it was a very successful first engine start, thank heavens. Thanks to KSC and BDH, their help is greatly appreciated. I would not be able to get this far without the help from all my family, so thank you.
