I had ordered some dual core AWG 20 shielded wire which arrived today. The temperature sensor for the airbox is arriving tomorrow. I worked on the harnesses for connecting the temperature sensor to the GEA24. The harness requires a 1 k ohm resistor to be connected from the Temp Hi wire to a Temp +5V wire, therefore three pins to the GEA24 J244 D-Sub connector. ( positions 14,15,16 ).
