Worked on the coolant hose which needed to be cut and rejoined. I was supplied with three coolant hoses which I assumed the third was intended to be cut to length to attach to the radiator. I was also supplied with worm clamps and two 1" aluminium connecting tubes. I have only done the left side today, I will install heat shield in the next couple of days.
