Peters Web Site
Date:  2-28-2023
Number of Hours:  5.00
Brief Description:  Windscreen.
A busy day today, with help from AEC we started cutting the windscreen.
This is definitely a minimum of two person job.
I would not have been able to do the cutting and trimming without the help from AEC, thank you.
After a number of very deep breaths and a nod to each other the cutting finally began.
I used a 100 mm " Disc Grinder " with a 100 X 1.0 X 16.0 mm " Cut-Off Wheel " to cut the Perspex and it worked quite well.
I have rounded the sharp edges with 220P sandpaper and now I will have to abrade the bonding surfaces with 80 P sandpaper.
Disc grinder.
Disc grinder.
Windscreen fitted.
Windscreen fitted.
Windscreen sitting in position.
