I wanted to have the GDL50R antenna mounted on the centreline of the aircraft. ( just to keep things symmetrical ). I made a backing plate to rivet the antenna to and will use it as a temp plate for drilling holes. I decided to install the antenna under the baggage comparment floor, for two reasons, one I can access it through the inspection ports in the floor and the second, it will be well away from the transponder antenna. GDL50R installation manual states the antenna should be at least 3.3 feet ( basically one metre ) from the transponder antenna. There will be approximately two metres ( 7.5 feet ) between the GDL antenna and the transponder antenna. I will consult BDH tomorrow before drilling any holes into the fuselage, to ensure I am not making any big errors I have not thought about.
