Peters Web Site
Date:  4-16-2020
Number of Hours:  4.00
Brief Description:  ELT
Started wiring the Artex345 ELT.
The "cup" pin connector are difficult to solder and as Craig M previously said you need about four heat resistant hands and fingers.
AEC helped holding the soldering iron which made a huge difference, even with the "helping hands stand".
I can not finish the plug as the ground and ELT RX wires are in a loom ( still on test bench ), however I will be able to wire the buzzer to the plug.
ELT plug.
ELT plug.
Buzzer.
Buzzer.
Buzzer and plug.
Buzzer and plug.
