I revisited the door lock handle installation. The build manual did not make sense to me and previously I was missing some parts, which I now have. The front latch would not fit on to the square shaft,( it has to slide down the shaft ), so after a small amount of filing it now fits. One front counter sunk knob was not quite right, the counter sunk hole was too small and not allowing the buttonhead screw head to be seated. I modified a buttonhead screw to make the head slightly smaller and now it fits correctly. The manual quotes the incorrect screw lenghth for the front counter sunk knob. Once I modified the parts to fit correctly and used correct length screws, it started to makes sense.
