Peters Web Site
Date:  5-29-2020
Brief Description:  Ignition switches.
Made an ignition harness from engine plug two, to the electronic module.
AWG 18, single core, shielded wire is used and I used solder sleeves to ground the shields.
Mag A is the right ignition circuit ( top plug ) and Mag B is the left ignition circuit ( bottom plug ).
Ignition harness.
Ignition harness.
Green shield ground.
Solder sleeves and ground.
