I have had a packet from the factory marked "Round Nut Neck Set" for years and have had no idea what they were for. Yesterday as I was installing the alternator it dawned on me. These are the nuts that the propeller extention bolts use to attach the extension to the engine. These nuts are not seated yet, they will pull in when the extension is bolted to the engine. There are two temporary bolts on the front of the engine holding things in place until the extension is bolted on.
