Peters Web Site
Date:  1-27-2020
Number of Hours:  3.00
Brief Description:  Painting.
I realised I had not drilled a hole for the beacon wire on the upper rudder leading edge.
The factory use the second rivet down from the top for the beacon wire grommet hole.
I did the same, however in addition I installed two extra rivets around the grommet.
I had a short section of four core wire which I threaded through the grommets to test fit and it's all OK.
Finished "Scotchbriting " the vertical stab. so ready for delivery to the paint shop.
No hole for beacon wire.
Grommet and rivets installed.
Ready for painting.
Ready for painting.
