Peters Web Site
Date:  9-3-2019
Number of Hours:  4.00
Brief Description:  Pitot/StaticTubing.
Spent time today trying to fix the pitot and static tubing problem.
After noticing the grommets had failed, the only way I could fix the pitot and static tubing was to remove them and start again.
From the wing root there are five ribs under the step, which I can not access the middle three to install grommets.
I decided to install two aluminium tubes, ( covered in black heat shrink ) with grommets at each end, that will allow me to thead the pitot/static tubing through.
I think it is a good fix, I will check with BDH for his advise later in the week.
Wing root.
Wing root.
Wing rear step rib 5.
