KSC and I went to the paint shop to install the replacement rivets as per SB 014. It took us about one hour 30 mins to replace the 62 rivets. I drilled the rivet heads then tapped them out, KSC caught them inside with the magnet. Thank you Karen, well done, job finished. I will fill the heads tomorrow and Richard ( the painter ) will respray the area with primer. SB 014 now done, I'm very glad the final paint coat had not been applied.
