Peters Web Site
Date:  6-23-2019
Number of Hours:  1.00
Brief Description:  ELT Switch.
Back home for two days, off to JNB this week.
I installed the ELT switch on the inside left hand side center console panel.
I had no room on the instrument panel, so I had to find another spot.
Daniel from the factory, suggested the inside panel where the factory have installed a number of ELT switched in the past.
The ELT came with screws and nuts for mounting, I decided to use rivnuts that will make it much easier for installation and removal.
Mounting hole cut.
Mounting hole cut.
Switch fits very well.
Installed using rivnuts.
