Once again I've been busy at work, unable to get into build shed. I had issues with the harness plugs the factory installed on the control stick harnesses. One end of the connector needs to be removed to thread through the control stick. I tried for hours to remove the connector and I just could not remove all the pins. I was in JNB last week and they said they changed the connectors for that very reason. Martin ( their avionics man ) could not remove the pins either. So I removed the connector and installed my own. Much easier to remove and reconnect in the future.
