Peters Web Site
Date:  6-18-2019
Number of Hours:  6.00
Brief Description:  Control Stick.
Once again I've been busy at work, unable to get into build shed.
I had issues with the harness plugs the factory installed on the control stick harnesses.
One end of the connector needs to be removed to thread through the control stick.
I tried for hours to remove the connector and I just could not remove all the pins.
I was in JNB last week and they said they changed the connectors for that very reason.
Martin ( their avionics man ) could not remove the pins either.
So I removed the connector and installed my own.
Much easier to remove and reconnect in the future.
Factory connector.
Factory connector.
My connectors installed.
Job finished.
Job finished.
