Peters Web Site
Date:  2-3-2019
Number of Hours:  1.00
Brief Description:  Rudder.
After I test fitted the rudder, I had troubles installing the washers above and below the hinges.
The rudder appeared not to be sitting straight on the hinges.
I ran a string line down the three hinges on the rudder and they seemed to be aligned very well.
( Photos below )
The three hinges on the vertical stab. were not aligned very well.
It took a little time to decide the number two hinge was not correct causing the alignment issue.
Des was in JNB and picked up a new hinge last week.
I removed the old hinge and replaced it with the new one and the issue was solved.
The rudder now self centers beautifully, its a shame I will have to remove them for painting.
Bottom hinge rudder.
Top hinge rudder.
Top hinge rudder.
Middle hinge rudder.
