Peters Web Site
Date:  11-13-2018
Number of Hours:  1.00
Brief Description:  Over Flow Bottle.
The factory attaches the over flow bottle to the bracket with cable ties.
I made two brackets to attach the over flow bottle.
I'm sure it is better than cable ties and it looks much better.
I installed foam inside the backets to protect the bottle.
If this does not last it will be very easy to install cable ties later.
I was going to use a rivnut to join the two brackets, however I think a small bolt will be better.
Foam installed on one bracket.
Brackets.
Brackets.
Over flow bottle.
Over flow bottle.
