The factory attaches the over flow bottle to the bracket with cable ties. I made two brackets to attach the over flow bottle. I'm sure it is better than cable ties and it looks much better. I installed foam inside the backets to protect the bottle. If this does not last it will be very easy to install cable ties later. I was going to use a rivnut to join the two brackets, however I think a small bolt will be better.
