Peters Web Site
Date:  9-12-2018
Number of Hours:  1.00
Brief Description:  Nose Spat.
I have been trying to figure out how to find the nose wheel tow bar bracket hole, so I could drill them.
Then I saw Craig M's blog and suddenly knew how to locate the holes on the bracket inside the spat.
Thankyou Craig, I thought I would have to remove the nose wheel, but a small torch did the trick.
Spot the hole.
Spot the hole.
Hole drilled.
Hole drilled.
Easy when you know how.
