Peters Web Site
Date:  5-7-2018
Brief Description:  Throttle Quadrant
I was contacted by a Sling4 builder, he was concerned about his throttle cables.
His throttle cables were tending to bow when the throttle was moved.
I inspected my throttle assembly and noticed that the "Bolt bush for throttle cable " were both very tight.( Could not rotate in the throttle push-pull link )
This would cause the cables to bow as the throttle setting was changed, as the bolt bushes were not rotating.
I removed the bolt bushes from the " Throttle push-pull links " and used some emery paper on both " Throttle push-pull links " to free up the bolt bushes.
Both bolt bushes now rotate as the throttle setting is changed, much better than it was previously, this should stop the cables bowing.
Throttle assembly.
Throttle assembly.
Bolt bush for throttle cable.
Will now rotate on throttle push-pull link.
