Thanks to the efforts of BDH we have a wiring diagram from SteinAir in Minnesota. It shows all the wiring required, pin numbers, wire AWG requirements, plugs etc. I may now have a chance of wiring the aircraft, which has been causing me some concern. Thank you Des, you are a very handy man ( just down the road ). I installed another anchor point in the middle of the aft floor of the luggage locker. I am unable to rivet it into position yet as it sits in front of a rivet hole. I will rivet it in position after the floor has been installed.
