Peters Web Site
Date:  10-7-2017
Number of Hours:  3.00
Brief Description:  GMU11 Mount.
BDH visited the factory last week and picked up a number of GMU11 mounts.
The factory advised the best position for the mount, which is very tricky for me, as I have covered in the rear skins of the aircraft.
I made a jig to allow me to drill the rivet holes in the correct position on the rib 4 flange as I was unable to see very well inside the fuselage.
I found that it was much easier to drill the rivet holes on rib 4 flange with the aircraft upside down and reaching through the luggage compartment with the floor removed.
Jig for the mount.
Jig for the mount.
Jig clecoed.
Jig clecoed.
Pilot hole in the middle.
