Peters Web Site
Sling4
Filling Rivet Heads.
Spent two hours filling rivet heads on the underside of the aircraft.
Managed to get the entire underside completed.
It is a very fast method once you get started.
I will allow the resin to harden over the next couple of days before sanding.
Rivets heads filled.
Rivet heads filled.
Bottom of firewall.
Sling4 Home
2991
352
475
Firewall
Flight Controls
Flight Controls.
Front Windscreen
Fuel Tanks
442
72
87
Propeller
49
87
Propeller
Undercarriage
Undercarriage
Upholstery
Upholstery
Windscreen
207
