Peters Web Site
Date:  1-29-2017
Brief Description:  Filling Rivet Heads.
Spent two hours filling rivet heads on the underside of the aircraft.
Managed to get the entire underside completed.
It is a very fast method once you get started.
I will allow the resin to harden over the next couple of days before sanding.
Rivets heads filled.
Rivet heads filled.
Rivet heads filled.
Bottom of firewall.
Bottom of firewall.
