Peters Web Site
Date:  3-21-2024
Number of Hours:  6.00
Brief Description:  Carburettor Synchronising.
With the help and knowledge from BDH we managed to get a number of tasks completed this morning.
I was not sure whether the aircraft was tracking straight when I was taxiing.
BDH stood behind the aircraft as I taxied along the runway and observed it was tracking straight,which is a relief.
We then checked the three propeller blade angles and they are all within .3 of a degree of each other. ( tolerance is a maximum of .5 of a degree ).
With the expertise of BDH we then synchronised the carburettors.
They were very close to correct, we only had to adjust one throttle cable adjuster nut by 1/4 of a turn.
Thank you Des for the use of your " Carbmate " and your guidance and knowledge of how to sync. the carburettors.
Carbmate connected.
Carbmate connected.
BDH at work.
BDH at work.
Threading through the cabin air NACA.
