Peters Web Site
Date:  3-16-2024
Brief Description:  Elevator Rigging.
KSC and I rigged the elevator, which is reasonable straight forward.
It is definitely a two person task, thank you KSC.
The elevator is now 30 degrees up and 20 degrees down.
The two limits are within .2 of a degree depending on how you breath.
Elevator zero.
Elevator zero.
Twenty degrees down.
Thirty degrees up.
Thirty degrees up.
