Fitted the rose joints on the flap torque tube and the aileron bell crank. Riveted the flap torque tube retaining ring into position. With the help from KSC I cut back the bottom wing skin so it would not overlap the bottom of the fuselage. The right bottom skin was cut correctly at the factory but it now matches the left wing bottom skin which was cut incorrectly at the factory.
