We had another successful engine run today. KSC gave me a hand to remove the aircraft from the build shed and kept a close eye on what was happening during the engine run. I had a headset plugged in and there was noise coming through the intercom or radio from the alternators. The problematic AUX fuel pump worked perfectly, I used it for the start and most of the engine run. I still have the protective plastic on the flight displays, so the photos are a little blurry.
