Peters Web Site
Date:  7-30-2023
Brief Description:  Coolant Radiator.
I installed the coolant radiator and the coolant a couple of days ago.
I have discovered the radiator has a pin hole leak in the welding join of the hose connection.
I should have noticed the pin hole before I installed the radiator.
KSC and I removed the radiator today and I cleaned the weld and the hole is quite obvious.
I will take it to an aluminum fabricator and get it re-welded this week.
A pain in the rear end, however better to find it now than later and it is a reasonably easy fix.
Radiator installed.
Radiator installed.
Coolant leaking ( pink ).
Pin hole in weld.
Pin hole in weld.
