Peters Web Site
Date:  6-16-2023
Number of Hours:  3.00
Brief Description:  Coolant Hoses.
I worked on the coolant return hose from the radiator to the coolant pump.
With the help from KSC I managed to get the return hose connected to the pump which is on the rear of the engine.
( I should have installed the hose before I mounted the engine. )
KSC helped with the lower cowl, which we had to install and remove a number of times, definitely a two person job. ( we are quite good at it now. ).
I made a support bracket for the coolant hose on the left side.
I will wrap the hoses with heat shield, which I have to order next week.
Coolant hose.
Coolant hose.
Coolant hose.
Coolant hose.
Coolant hose.
Coolant hose.
