Peters Web Site
Date:  6-14-2023
Brief Description:  Coolant Hoses.
Worked on the coolant hose which needed to be cut and rejoined.
I was supplied with three coolant hoses which I assumed the third was intended to be cut to length to attach to the radiator.
I was also supplied with worm clamps and two 1" aluminium connecting tubes.
I have only done the left side today, I will install heat shield in the next couple of days.
Coolant hose join.
Coolant hose join.
Coolant hose join.
Coolant hose join.
Coolant hose join.
Coolant hose join.
