Peters Web Site
Date:  5-4-2023
Number of Hours:  4.00
Brief Description:  Oil Hose.
I purchased some heater hose which is 19.05mm I/D, which fits over the oil hose.
I will use this hose to protect the oil hose from possible rubbing areas.
I have been thinking of how to secure the oil hose as it passes the alternator.
TAF use cable ties, however , a P-Clip would be much better.
I made a bracket and riveted it to the alternator support arm and then used a P-Clip to secure the hose.
I stiil need to install some heat sleeve on the oil hose in the area above the exhaust pipe.
Support bracket.
Support bracket.
P-Clip on oil hose.
P-Clip on oil hose.
Oil hose.
Oil hose.
