Peters Web Site
Date:  2-9-2023
Number of Hours:  4.00
Brief Description:  Lock Cam Rollers.
Installed the lock cam rollers and had a few issues.
When drilling one of the rivnut holes the bit grabbed and the hole ended up about 1-2 mm lower.
I installed the 5mm rivnuts with ' J-B Weld ' for extra strength.
After thinking all night of how to fix the issue of the lower rivnut, my only option I could see was to dremel the door latch lower. ( seems to have worked OK )
The doors locks were tighter than I was comfortable with, so I removed the brass bushes and the doors now close much better.
If the door rubber settles over time I will be able the slip the bushes on to take up any future slack.
Left front door latch.
Left door latch.
Left door latch.
Left front lock cam roller.
