KSC gave me a hand to reinstall the cabin doors, which still need painting on the outside trim. I needed the door on to position the striker plates for the latches. I managed to bend the striker plates around the door frame and they fit better than I expected. I will install the rubber door seals prior to installing the latch 5mm capture roller screws and rivnuts.
