I removed the lower cowl and removed the oil radiator to install the M14 adapters. The adapters are now fitted and torqued to 22Nm with Loctite 243. I do not have enough oil hose to connect the radiator to the oil thermostat. I will order some from the Australian Rotax agent in the next couple of days.
