Peters Web Site
Date:  11-30-2022
Brief Description:  Oil Radiator.
I removed the lower cowl and removed the oil radiator to install the M14 adapters.
The adapters are now fitted and torqued to 22Nm with Loctite 243.
I do not have enough oil hose to connect the radiator to the oil thermostat.
I will order some from the Australian Rotax agent in the next couple of days.
Adapters.
Adapters.
Adapters installed.
Adapters installed.
AN8 fittings.
AN8 fittings.
