When I installed the Dzus fastener on the cowls I did not realise that the bottom two fasteners on the lower cowl are longer than the others. This is due to the thicker aluminum bracket on which the retaining springs are installed. By chance I did install one of the longer fasteners on the bottom without realising I had, however the other was a shorter fastener. I had to remove the shorter fastener because it would not engage the retaining spring. I difficult job which had a huge potential for damaging the cowl. I managed to remove the Dzus fastener with minimal damage. The bottom two fasterns are AJ5-40 ( .400 Inch ) and the remaining fasteners are AJ5-30 ( .300 Inch ). I also reinstalled the radiator fastening levers.
