I decided to re-do the mounts for the GEA24 and GDL50R. I have used heavier material and re located the anchor points. The unit now sits higher on the front top rib, which is much better. I installed strengthening ribs, installed rivnuts and primed the mount. I will install it back behind the panel tomorrow.
