I was only supplied with two "Canopy Hinge Slot Cover Angles " ( CHSCA ), which were not bent. I made another two, which was very simple. I will bend the CHSCA to ninety degrees when I rivet them to the hinge slot cover. The angle on the CHSCA holds the canopy hinge bolts in position, as there are no nuts attached on the bolts.
