Peters Web Site
Date:  5-9-2022
Brief Description:  Heater Air Pick-up.
A couple of days ago KSC and I did our best to mark where the hole for the heater air pick-up should be drilled in the lower cowl.
I drilled a 44mm ( one and three quarter inch ) hole in the lower cowl with a hole saw.
KSC and I nervously attached the lower cowl and thank goodness the hole is in the correct position.
I think the pick-up tube is a little short, ( maybe not ) so I'm ordering some longer tube.
44mm hole drilled.
44mm hole drilled.
Heater pick-up fits very well.
Maybe a little short?
