Peters Web Site
Sling4
Sensor Wiring.
Finished wiring the pressure sensors and fuel flow sensor, all wires are numbered to correspond to the engine number one plug numbering.
All engine instrumentation is indicating correctly on the G3X for an engine that is not running.
Engine plug # 1. Fuel pressure, Fuel flow ,Oil pressure, Manifold pressure.
Engine plug # 2. Shunt, RPM, Mag, Caution, Boost, TCU.
Engine plug # 3. EGT.
Pins installed and numbered.
Engine plugs.
Engine plugs.
Sling4 Home
2955
353
475
Firewall
Flight Controls
Flight Controls.
41
89
Front Windscreen
66
Fuel Tanks
25
66
447
81
87
Propeller
49
87
Propeller
Undercarriage
25
66
Undercarriage
41
89
Upholstery
Upholstery
Windscreen
198
