I placed the fuel pressure sensor into position with the longer banjo connector. ( fuel supply tube yet to be connected using longer connector on the banjo ) I am still " Umming and Arring " about the best way to install the FT-60. ( Fuel Flow Sensor ). I will source someone who can professionally silver solder the FT-60 connectors into the fuel supply line for the righthand carburettor.
