Peters Web Site
Date:  1-12-2022
Number of Hours:  4.00
Brief Description:  Choke Cables.
I shortened the two outer casings of the choke cables.
I installed some heat shrink on the end of the cable so it would sit a little more secure in the ferrell.
I safety wired the cable outer casing to the " bent tube assembly".
I'm not sure if my safety wiring is satisfactory, so I will consult with my technical advisor, BDH, before I apply heat shrink.
Safety wired.
Safety wired.
Safety wired.
Safety wired.
Safety wired.
Safety wired.
