Connected #10 wire to positive and negative terminals on the Power Panel These were connected directly to the battery terminals when testing the avionics, and then disconnected. They will be properly connected into the system and tied to the master at a future date.
Connected the following devices with the appropriate size wire:
Composite Design SP-2 Power Panel SL-40 radio GTX-327 Transponder MGL Odyssey EFIS/GPS TruTrak Pictorial Turn and Bank TL-Elektronic 3524 Digital Altimeter
Routed all wiring to avoid mechanical damage and to allow installation of the second MFD on the right side of the panel in the future. Will secure next trip
