Check the spar box to the cutouts and and adjust accordingly. Fit and cut, fit and cut until this is right.
Made adjustments as necessary and adjust spacers accordingly to get ready for fitting the wings.
Inserted left wing into fuselage, placing wing on support to level. Positioned the front spar box up against the wing spar. Inserted the AN5 bolts, then inserted the right wing spar and aligned both wings.
