Brief Description: Attached aileron pushrods to bellcrank
Alligned each aileron pushrod with bellcrank and attached with two washers, bolt and lock nut.
The easiest way to do this if you have large hands like I do is to use a magnet. This holds the bolt in place until you can put the locknut on it. Then it is easy to to tighten it down.
