Lightning N730AL Build Log
Lightning
Wired key switch
Routed a new 12 volt positive wire to the keyswitch side of the panel for the switch.
Cut all wiring to go to keyswitch to the same length. Crimped ring ends on wires. Grounded the shielded wiring to the mags on the keyswitch side.
Wired the keyswitch and wrapped all wiring in a protective tube to protect from vibration
Added two wire hangers to keep bundle out of the way.
Hooked up the battery, switched on the master and TURNED OVER THE ENGINE!!!
What a great feeling!
Lightning Home
Lightning Home
798
Body Work
Lighting
Planning
