Lightning N730AL Build Log
Lightning
Wing Tip Prep
Sand off mold flange from each wingtip.
Cut notch on top and bottom sides for clearance.
Remove gel coat from joggle for good bonding surface.
Trial fit wingtip.
Filled wingtip with foam and let dry.
Cut foam flat with opening.
Wingtip prepped and fitted
Lightning Home
Lightning Home
798
Body Work
Lighting
Planning
