Lightning N730AL Build Log
Lightning
Sanded Joggle Joint
Used a scotchbrite wheel to remove the gel coat from the window joggle joint. You have to go slow to be careful that you do not sand down in to the glass which is structural.
GO SLOW! Use a lower speed!
Lightning Home
Lightning Home
798
Body Work
Lighting
Planning
